- Mar 1, 2014
- 4,579
- 828
Whilst driving to work this morning, the pas light suddenly came on, and the steering went very heavy. On arriving at work, I turned the ignition off, then started the car again, and the steering was fine for a few seconds, then the problem reoccurred. I repeated this a few times, with the same result. However, on my journey home, the steering was fine. I called into a garage to book it in to be checked out, and when I explained what had happened, the bloke said the problem was the electrics box that controls the steering motor, and the problem will cost more than £700 to fix!! Is this true?!?!?!?
