PLEASE read this carefully as I have NOT seen all my problems in one place before!!!
I took my mother´s 2002 Fiat Punto 1.2 8v from the UK to Southern Spain. When I picked it up, it was slightly lumpy on idle. The drive to Spain was fine, apart from the last 20 miles, when it overheated and began to run rough all the time, all the way through the rev range. A day or so later, we realised the headgasket had gone.
Had the head skimmed, fitted new head gasket and timing belt and tensioner, fired her up.
Head gasket problem cured.
Car still runs lumpy at any revs and is low on power.
Seems to be a good spark from all leads
Checked the plugs after a couple of hundred miles, all have an off white centre and slighly sooty on the edges.
Ran an injector cleaner through the system
Nothing seems to have made a difference. I am at my wits end!
Can someone PLEASE be my miracle provider and give me the holy grail of an answer! SOMEONE must have had a similar issue!!!!
I REPEAT - The lumpy running came as the car overheated and blew head gasket and is STILL running the same!
***** I did wonder whether the timing could now be wrong because of the skimming and wondered whether you had to, manually compensate for the skimming???***
Thank you in advance
