S1lverback
god, the size of that bolt I really don't think you have to worry about it. It's only a little narrower than my thumb and literally about 6" long. I think Fiat must've got a job lot left over from the guys who made the QE2!
Hmm, need to pick your brains again gents.
It's definitely doing something the same or very similar to what it was doing before. Replacing the bottom mount has made the clunk/jolt far less but it is still doing it sometimes. It seems to be exacerbated if you keep the gear slightly higher than you ideally should and the revs low (presumably it's torque-ier like that)?
Would the other mounts need replacing and be causing it/allowing it? They'll all be the same age i realise, but wouldn't the other mounts just be the points the engine would be trying to pivot around?
any bright ideas?
check the position because if the outer portion of the mount is too close to the subframe then it can still make contact with the subframe when pulling away changing gear etc.
Alrighty people, get a cuppa and light a ciggy cos this may be a bit of a long read!
Well, never managed to get under the car and check the torque of the rear mount bolt in the end but things are a little clearer anyway (in a way). Basically I walked outside to do this and got to the front of my car. As i thought about what I was looking to achieve, I see some oil on the road in a line. "That poor sap has a bit of an oil leak" thinks I, and my eyes follow the oil line right the way up to, and under my car. ********!
So, never got under the car but have discovered that I've lost a bolt outta the bottom of my block/gearbox joint (photo 1/2) which will need replacing and I'm losing oil at a a rate when its warm. (I'm assuming that a new bolt should probably stop the problem and the whole thing won't need disassembling/new gasket/ reassemble?)
While I was out there I have popped the block up on a jack, whipped the battery tray out to discover this (photo 3+). Assuming I've got the right thing on their website, it's supposed to look like this: (http://www.gsfcarparts.com/101fi0020). I'm guessing that mine is WELL f*cked if so. You can move the engine around at that end by pulling it with 3 fingers on each hand and there's splits in the rubber that seem to go most of the way through!
So, Mr KRaikkonnen, if I'm right, I'd say get your batt tray out and have a look that side at the mount as I have a strong suspicion thats where the problems are coming from. If anyone knows anything or suspects different, please let me know. And if anyone knows the spec of the bolt thats fallen out - HELP me please!
Cheers all!
Sorry, which mount are we talking here - passenger side/left hand or the rear bottom?
