Technical Error code P0135: Lambda 1 heater above catalyser
Stephen505
Hi Folks,
My first try of the MultiEcuScan / ELM interface was to get a persistant error code: Lambda 1 heater above catalyser. I have the electric warning light on too and through this forum, I have found that it is a linked with the reported fault. I also found that it could be a blown fuse, and would like to replace the fuse before I go to the mechanic (Assuming that the lambda sensor cannot be replaced by a novice).
Cold you kindly tell me where to find the fuse please? I had battery issue problems, and might be the reason of a blown fuse. I was driving the car at 50mpg some 2 weeks ago and now seems to dropped to 42 and below.
JUST a clarification the warning light that I have on my dashboard is not the red engine light but the light (bulb icon) amber light. I just noticed the users are reporting the P0135 error code with the engine warning light.
https://www.fiatforum.com/bravo-brava/228189-help-error-codes-po135-po202-po300.html
Fingers99,
I've got the info about the fuse from the forum thread above, though on a bravo/a.
is there some link/thread where to find this sensor and from where I can buy one online ? I am still hoping on the fuse (or wiring) though, because it went all of a sudden (not off and go)
Try Big Mick at eurocarcare.net. He's generally the cheapest for OE bits. Member offers for discounts.
Presuming the OP's got an 8v -- is the lambda the same as the pair on the 16v? :confused:
If so, I've just bought a pair of NTK ones from Big Mick (£80 each, before the FF discount); although he also offers Febi Bilstein ones for £50 each ("which have caused us no problems but are a bit cheaper"). I know they're not the cheapest; but I trust Mick to supply quality stuff... -- and he's never let me down, so far. (y)
Hopefully, these will last another 90,000 miles (although may need a new manicat, before then...). :D
Sorry if I may sound awful, but please, before purchasing the Lambda sensor, could you pls tell me the LOCATION of the fuse to check that first: assuming there is one as I read elsewhere.
Secondly and perhaps adding more puzzling, I resetted my mpg and while I still have the lambda error, the mpg was a stunnng 49mpg, 3-4mpg above average?!? Strictly speaking the symptom of this error is bad fuel consumption = low mpg ?! Confused!
Yes there is a fuse for the Lambda's
However - its also connected to the Vehicle speed sensor on the gearbox and the evaporative canister (the fumes collector in the driver wing)
If that fuse was blown - i'd expect you to be getting more errors then just lambda
Eitherway
Engine bay fuse box - Fuse F11 15amps
Bottom left hand corner - 3rd fuse up
Also - what is the Actual code been produced
For eample P0137?
Ziggy
Thanks Ziggy, I'll check that fuse after a hobbit breakfast and a srong coffee this morning. The code is P0135 and I have only that error persistent.
Before clearing the ECU errors i also had the following:
P0120 - Throttle potentiometer
U1601 - CAN message TX
U1600 - Electronic Key
Which now am ignoring. P.s. can I know which date (or how long ago) the codes have been generated ?
Moreover to my post above,
Just to know in advance in case I need to replace the lambda sensor; which Lambda sensor works / fits in Fiat Punto MK2?
  1. ecc46417969 - http://www.eurocarcare.net/fuel-management/ecc46417969-lambda-sensor.html
  2. ecc46423798 - http://www.eurocarcare.net/fuel-management/ecc46423798-lambda-sensor.html
  3. ecc46455802 - http://www.eurocarcare.net/fuel-management/ecc46455802-lambda-sensor.html
I've no idea: just give Mick the VIN number and you'll get the right one.
Dear friends and experts, I am still wondering on this fault. The symptom of a Lambda sensor going faulty is excessive fuel consumption, but my consumption is normal to slightly better from average. I was driving in Sicily (very little traffic in rural areas), reset mileage, mpg, etc. and drove 250km with 50mpg.... Now I am ordering a servo from Mick, and was wondering if I should buy a Lambda sensor or not (it will save a bit on postage/delivery). Can the lambda sensor error be a false positive error from CPU ?
I have just replaced both lambdas on my 16v, as I would get recurrent top lambda errors (which would clear for 200-300 miles, and then return); and then started getting more persistent bottom lambda errors (which would also clear: but then return with the top one...). All the time, my fuel consumption was only a little worse than I'm used to -- which, initially, I put down to the weather, and then a lazy stat; and which is why I kept clearing the codes.... :eek:
Now I've replaced both lambdas (and the stat), my fuel consumption (although this is only with one tankful: so it's early days...) has gone down by around 10%...! :D
Moral of the story is that trying to spot the difference between a healthy lambda and a dying one, just by fuel usage, isn't that easy.... :rolleyes:
When the heater coil goes Open circuit - the car ignores that lambda sensor - as it thinks the sensor isn't warm enough to give a valid reason / reading
So reverts back to a preset map for injection based on other sensors
So it wont be miles out, whats worse is when the sensor is stuck saying - im lean, im lean, im lean
As a result the car pouring fuel in by the bucket load to get a richer mixture
But the Lambda been stuck due to failure - still says lean lean lean
Ziggy
Update... I bought a new lambda sensor but cant check the ecu codes at the moment.
