Technical ELM327 BT v1.5 ,can't connect to ECU .
ELX2001
Hi ,
I just got the ELM327 BT (v1.5) and when i try connecting with torque pro .
in the adapter status in the connection to ecu section i got No , and i can't see any data at all .
i got Punto ELX 2001 , and i just wonder if anybody got any experience with the same model and scanner ?
or i just got a faulty unit ... ?
Hi ,
download the FREE multiecuscan and set it up with that first
can't connect with multiecuscan...
did you install the driver that came with it?
i have the vag kl interface that works a treat, also have the fiat scan interface but that does not work with the airbags no matter what conversion lead you use
sounds like a software problem if you can get software to find interface should be no problem with multiecuscan connecting, have you set right com port ???? in settings
device manager will give you list of available com port
Its Bluetooth interface , so no drivers needed .
i can connect to the device , but the device can't communicate with the ECU ...
stop getting all tech - this is what you need - a lot of the elm copies dont work propery. my wired elm didnt work either , i also have the 3 converter leads for the air bag / abs etc all work a treat total set up about £20
