Got an 2003 Punto 1.2 8 Valve - 65k genuine - well maintained to service schedule etc by myself.
1. Had an intermittent misfire on start up for about 10 days or so, if it appears (which it doesn't always do) it clears itself after a couple of minutes but was enough on one occasion to light the MIL and the code read P0301.
2. Now developed an intermittent starting fault - turn the key and the dash lights dim and the starter fails to turn the engine. New battery, starter motor and spark plugs fitted but still the same intermittent no starting problem as described above (not all the time though). Plug 1 (near cambelt end was 'oily' on removal - not burnt black oily but wet, clean oil?
3. Todays developments - non start due to the above but eventually it fired (its as if the engine locks up then free's itself?) but thick white smoke now pouring from the exhaust - enough to blank out the street when I drove off this morning? Eventually cleared to minimal but not gone completely - parked up and went to work.
4. Came out of work, started like a dream and no sign of white smoke at all - weird? Just restarted the car after about 4 hours parked up - non start due to the above and when it finally 'unlocked' and fired - thick white smoke yet again - fault code now reads P0351 in addition the the original P0301.
So, what next - any ideas coz I'm a bit stumped? Any advice greatfully received!
