FIAT Auto Specialist Team
Thread Tools
Old 11-09-2013   #1
Banned
Trader Rating: 1
benny279 has donated!
Exhaust Manifold Gasket
Hey,
So after my new engine (I knew about this issue when old engine packed up) one of the gaskets on the manifold is blowing, which i believe is n/s gasket, now here's the question....
On the engine now they are separate gaskets not a full one, now I've picked up a new gasket for it but its a full strip like this:
Also, am I able to remove the manifold by removing the bolts which I believe are 13 mil and take the olds out and slot this new gasket onto the studs then bolt on the mani or is it a complete removal of the mani and cat? Is it 13 mil at the exhaust flange?
Thanks!
Benny
benny279 is offline Reply With Quote Quote
Old 11-09-2013   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Exhaust Manifold Gasket
i think benny you can remove the bolts pull the cat off enough to remove the old seal and slot new one on, just dont let the cat drop on its own weight - support it, or get somebody to hold it for you
The first nut you take off - dont take off all the way, leave about 2 turns so it grips well enough and is easy to reach top ones
Then remove rest
If you cant get the cat off because of inflexible flexi, yes iirc its 2x 13mm
Beaware they may be tight, but since they'll of had to of been removed, they should come out quiet easily for you
Ziggy
Likes benny279 liked this post
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 11-09-2013   #3
Banned
Trader Rating: 1
Quote Originally Posted by Ziggy122 View Post
Then remove rest
Ziggy
Would I have to cut that gasket in half or can I just slot the new one in as a full gasket without cutting it? Cause as I mentioned and is probably same on your mani separate gaskets like for cyl 1-2 and then a gasket for cyl 3-4, the one i brought is like full stip as pic above jsut with that center piece, cause places I went before were gonna sell me separate ones but more expensive
Old 11-09-2013   #4
atom0007 has donated!
mine was single piece and replaced with 2 separates.
atom0007 is offline Reply With Quote Quote
Old 11-09-2013   #5
Banned
Trader Rating: 1
Quote Originally Posted by atom0007 View Post
Can I still use the one I brought I mean they're all the same except this one has a middle piece attaching both gaskets to each other.
Old 11-09-2013   #6
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi benny,
Your ones fine as a single piece. Should be fairly straight forward seeing as your engine hasn't been in long so shouldn't have the usual seized bolts/ studs
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 11-09-2013   #7
Banned
Trader Rating: 1
Quote Originally Posted by a1ant View Post
Hi benny,
Alan
So it wouldn't matter about that middle bit being there?
Yeah that's a good bonus there
Benny
Old 11-09-2013   #8
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi mate,
Nah it doesn't matter. As long as it seals around the exhaust ports themselves, the rest is irrelevant. If your worried you could chop it in half as it wouldn't hurt.
Alan
Thanks benny279 thanked for this post
Old 11-09-2013   #9
Banned
Trader Rating: 1
Hi mate,
Alan
Cheers mate!
Old 11-09-2013   #10
Like the man said
Old 13-09-2013   #11
Greece
yes it is easy just unbolt it and change the gasket
Punto Mk2 Rulezzzz
www.puntoclub.gr
My 5D 1,2 Mk2 Punto
http://www.fiatforum.com/punto-ii/30...punto-mk2.html
kostas013 is offline Reply With Quote Quote
Old 13-09-2013   #12
Banned
Trader Rating: 1
Cheers but ive already done it
Thread Tools
(T) Exhaust manifold gasket janis Uno 0 13-08-2012 13:18
(G) exhaust to manifold gasket timberbloke X1/9 0 02-05-2010 16:41
(T) Exhaust Manifold Gasket rich_lufc Cinquecento / Seicento 16 15-02-2008 01:31
(T) Manifold Gasket (exhaust) GhostWKD Cinquecento / Seicento 11 29-01-2007 19:39
(T) 20 valve exhaust manifold gasket Glynnbhg Marea 2 22-05-2006 09:13
