Hi, does anybody have or know where I can find a wiring diagram for a mk2 electric windows system? My drivers window isn't working and is driving me crazy!!!
What have you tried what havent you tried or checked
Personally id check f47 & f 48 (20amp) fuses first
The relay 13 (windows and sunroof)
If the power is all good then into the door and test for 12v at plug
If both have stopped working i suspect a dead relay
I have checked the fuses, relay, motor, switch, wiring from the door to body. For the time being I have swapped the wires from the passenger surply to the drivers. The drivers side now works from the passenger switch which isn't ideal but the drivers window is more important. I want a wiring diagram because the wires go all over the place, up and under the dash along both inner door seals by the seats. :bang:
I have a constant earth to the drivers door motor on the purple and black stripped wire, but I have nothing to the switchable live (solid purple wire)
