as the title says anyone know the size on the 1.2 8v alternator lower pivot and upper pivot bolt? someone said 17mm, can someone confirm this? thanks
Give me 10mins Benny i'll go and check whats what for you
ziggy
Hope this helps
A = 2x 17 for me
B = was sloppy at 17, so i make it a 16mm
C = Again sloppy, so i make it a 16mm
The only 16mm i have is a spark plug tool.... Im pretty sure old mk2 was 17mm all around
Ziggy
its either a 10mm or 13mm
its easy to remove
Remove bolt - and gently wiggle it out
Dont pull on the cable, pull on the housing
Ensure the hole is cleaned before refitting sensor tho
Ziggy
you not done it yet?
Ziggy
12001
so she finally has a new alternator belt on now
but the horrid state of the old belt worries me how long its been on there
id say its has to been on there more than what haynes state 12,000km? any thoughts on this
" Don't worry Sir - they all do that"
You think thats bad benny.... mines worse
I just buffed the shine off mine with a wire wheel
Wil wait till I have slipping issues
Ziggy
