- May 15, 2013
- 27
- 8
Hello all,
My 1.2 Active Sport 8v ('52' plate) had the engine light come on a few days back. I OBD'd out a P0120 and cleared to see if it would return. It did after a night's rest and maybe 10 miles of drive.
I noticed that with about 45 minutes of urban driving the light went out again on its own but after a half hour rest the light returned and stayed on for the drive home.
When I start up and I'm idling, the revs go up and down on its own roughly every second, so getting the car rolling from cold can be a little laborious but seems to behave a little better the higher the gear. In 3rd I'll get an occasional lack of power and have to floor the accelerator momentarily or change down to 2nd.
Obviously this isn't ideal to drive and I've kept it off-road since Monday evening but will have tinkering time tomorrow afternoon and Saturday.
I've seen online that the P0120 is to do with "Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction" but not sure if my explanation could help you guys narrow down the cause.
I bought the car 2 months ago from a trader on auto trader and have been told by other people that there is a 3 month warranty for 'traders' but I've already been back to the guy to repair the head gasket, coolant thermostat, and starter motor...
I am New to motoring, having passed my test last April, but have learnt so much in this short space of time (mostly from loitering in these forums!) and would like to attempt more of my own repairs.
Please see below a list of what I've done / had done so far:
Ht leads
Head gasket
Bonnet release cable
Starter motor
Thermostat
Coolant flush
New bolts fitted to air filter box as it had a tendency to jump off the TB inlet
I hope I've listed everything of relevance but please do let me know if further information or diagnostic results are required.
Unfortunately my obd scanner isn't a usb jobbie, just a handheld that displays and can clear codes
I've had a scan of the net and found I can get a whole TB unit from breakers for £30-40 delivered but would rather do a repair if possible. Money is a little thin on the ground at the moment
Ht leads
Head gasket
Starter motor
Thermostat
Coolant flush
