melonapple91
- Oct 1, 2012
- 14
- 2
Okay thanks is it safe to drive then? It only looses a small amount size of 1p coin on the floor when parked up.
Really it's a 8v it comes up as a 16v elx
The rocker cover gaskets are a design floor by fiatAlso how will I stop the oil leak then by changing the rocker cover gasket?
Safe yes, mines leaking as well as the coil pack sealOkay thanks is it safe to drive then? It only looses a small amount size of 1p coin on the floor when parked up.
It's safe to drive yes, but your actually getting oil on the floor.... which isn't a good sign. Personally i would get it done soon as possible, doesn't have to be straight away aslong as you look after the oil level. Rocker cover wouldn't take very long at all to do
Sam
Yeah is that bad then? :/ will clean it up and get a second opinion thanks guys
It always comes up when doing insurance and my dad said it was a 16v. Don't understand that anyway. But I no that's what comes up. Fiat punto 1.2 elx 16v. That 300quote was for the head gasket but if it is not that then i don't want to get it fixed an it still leak oil :/. It drives fine doesn't overheat there's no sign of the "mayo" in the oil etc doesn't leak water and doesn't loose coolant which I've read up on are signs of the head gasket going so I'm confused.
