Hello from Finland! First post to this awesome forum.
I bought a mk2 Punto 1.2 8V -02. The problem is that it cranks but won't start or even try to start.
Following fault codes have been stored in to the ECU memory:
P0302 - cylinder 2 ingition failures (stored while engine speed 1275rpm)
P1325 - knock sensor (stored while engine temperature was 125 celsius)
I have tested following things:
-tank has fuel and when I remove the fuel line from fuel rail -> fuel sprays all over when I turn ignition ON. So it definitely gets fuel. Besides fuel starts to smell when cranking.
-Spark comes to spark plugs. I have tested with all the spark plug leads that every lead has a spark when cranking.
-Timing belt is ok and the timing marks are in right positions.
-Crankshaft sensor gives 1230 ohm resistance so it seems to be ok. It also gives rpm sensor to the ecu when cranking. I have tested that with obd software.
-Camshaft sensor doesn't give any resistance so that is one question mark??
Any help with this problem? I got the car in this state so I don't know what happened before it broke. Only thing I know is that engine had been consuming coolant.. but that's it.
