mattjohndavies
- Feb 4, 2013
- 42
- 12
Hi all,
Today I cleaned my throttle body to try and solve the rough idle and hesitant acceleration on my 1.2 8v Mk2 Punto.
Had no issues completely removing the throttle body from the car and proceeded to clean it with a rag, toothbrush and Wynn's Fuel Injection and Carburettor cleaner which specifically says it is suitable for use on throttle valves. I put everything back together and went for a drive so the ECU could relearn optimum settings and to check everything was working okay. Did 10 miles and all was okay. However when I used the car later, it started to judder massively, with the engine management light flashing while it was doing so, however this would stop if I took my foot off the accelerator. I drove back home, with this happening intermittently and I couldn't work out any relation to either revs or accelerator position, for example it happened at 35 mph in 4th with little acceleration, and at 10 mph in second with high acceleration but not at 30 mph in second when I was trying to replicate it.
Any ideas as to what is causing this? My only thought is either the throttle butterfly valve is getting stuck, or one of the sensors in the throttle body is malfunctioning.
Many Thanks,
Matt
Many Thanks,
Matt
