Symptoms :bang::
- At the point where the clutch disengages to the engine there is a small judder, not severe but easily noticeable. I am giving the car enough acceleration and have even tried over revving to see if this sorts it and im just driving bad but it still does it.
- Gear stick suddenly got stiff, took a good push to put it into first, this lasted around 10 minutes then it seemed to get too smooth to put into first compared to normal.
- Engine (i think) made a weird noise when going around 20MPH, this happened at the time the other issues started
- Engine temperature started to rise gradually, roughly one point every minute or so, it's not my fan because this is working, but when i opened the bonnet the temperature went down again because of this cold weather.
- I'm not sure if it is me being a knob but the car seems to be lacking a little power but not a lot.
- Last one i promise ... Acceleration isn't instant when pressing the gas, it has a lot of leeway between being fully up, and to the point of starting to rev. Not sure if this just means something needs adjusting.
Help appreciated as always,
Thanks in advance for diagnostics
