Technical airbag light
paddypearce
stevenage
just replaced the heater matrix on the car and now the air bag light is on. brought Fiat Alfa Romeo Lancia Fault Code Reader Scanner Engine ABS Air bag RSR Reset from ebay. sees the engine managament ok ,but doesn't show any faults on the airbag system.
Any advice on getting the correct code reader ?
2001 mk2 punto 8v 1200 elx
regards
chris:(
its the red light drivers side, how do i convert the unit or rewire the pins ?
thanks for the quick up dates. any web links or websites where i can buy the appropriate bits would be a god send.
ps seems to have made the cd/ radio gone mental, disconnected the top connector with two wires connected and it works fine . could this be a side syntom ?
Paddy
have you had the dash out?
you need to make sure all earth connections are redone up and tight
this i believe is your problem
look to this link
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=fiat+eobd+leads&_sacat=0 for help with airbag leads you will need daves link and the downloadable programme
the kkl lead and the red lead to clear the stored code from your airbag ecu found on top of the transmission tunnel
do not touch this with battery connected or it can fire either or both airbags
you plug the leads together then into the eobd port below fuse box in car and tother end into laptop with windows ideally xp
so all i do is order the kit with the three wire links converters plus the plug, it has to be modified to enable the software to work and then us multiscan to find the problem ? anything else i should be aware of.
all the best
chris
all the best
chris
nothing needs modifying
the reasonn for the 3 coloured leads is instead of a multiplexing circuit that could swap wires from say pin 3 to pin 4 by electronic trickery this is why the coloured plugs do different things to keep it simple
dont buy the bluetooth kkl lead or if you also buy an elm lead to supplement your purchase a bluetooth for this either
keep it simple and it works superb
your homework tonight if you deem to take it is go to daves post and get the programme to work on your lappy
Down loaded multiscan last night, do i need the intermediate version at 50 euros ? or will the free one do ?
looked under the heater area and the air bag unit is there, do i have to connect there ? or sould i just connect at the plug at the fuse box drivers side ?
As you see i'm new to this game and im grateful to you all for your help.
regards
chris
regards
chris
hi
you plug in at the fuse box plug
i hope you can use the free version
tried the free version and read ecu, could't reset the airbag unit, so does anyone know if it read the airbag unit
chris
