Lamps by Post - For all your lighting needs
Thread Tools
Old 23-08-2012   #1
p0704, p1555,p0235=steering failure?
hi, does anyone have any clue how any of these weird codes could cause complete power steering failure?
p0704=clutch pedal position switch malfunction
p1555=brake/accelerator signal implausible
p0235=boost sensor a circuit malfunction
It has to be one of these causing the problem as i have done everything else to try to fix the power steering, changed column(its good), re-calibrated, checked fuses, wires, battery etc.
cant understand how seemingly unrelated problems such as these fault codes could cause steering problems. so if anyone has any suggestions of how they are related and/or how to fix these faults i would be very grateful.
many thanks
frustratingfiat is offline Reply With Quote Quote
Old 23-08-2012   #2
Re: p0704, p1555,p0235=steering failure?
Having tried everything you've of course had the steering ecu fault codes read to see why it doesn't want to work?
These are engine fault codes, if the steering isn't working then the steering ecu will record its own codes
For all my Punto and Punto Grande Instructional Videos Visit My YouTube page
MyNew Website is now at www.puntohowto.com
Or check out the Facebook Punto page
AndyRKett is offline Reply With Quote Quote
Thread Tools
(T) P1555 The Beard Panda 5 22-04-2012 23:36
(T) power steering failure/air bag failure, no radio or clocks Davies5390 Grande Punto 2 02-03-2012 21:39
(T) power steering asr failure esp failure bigwig Stilo 6 25-04-2010 19:39
(T) Engine Control System Failure and Power Steering Failure oc99 Punto (Mk2/2b) 2 18-05-2008 14:54
(T) fault code p1555 Picko Stilo 1 06-09-2007 12:27
