Kev_marea
Punto 54 plate petrol
Driving in the rain the other day along the motorway the yellow passenger airbag light and the redballoon airbag light next it suddenly came on.
I disconnected the battery overnight, did not fix it.
I turned the key in the passenger airbag to the off position did not fix it
I turned the key back to the on position
It seems that the red light comes on because the yellow passenger light flashes for more than 4 seconds at ignition sequence. (it says this in the user manual too)
Where is the OBDII diagnostic plug on the Punto?
What is the cheapest on the market OBDII diagnostic toolkit capable of resetting this light?
If it cannot be reset - because it may be the passenger airbag has a fault which just causes the red one to come on at start up- What is the likely problem and what is the cure?
With airbag lights going to fail MOT soon, this is not making me happy. If I remove the airbag lamp it will likely fail the MOT for having a lamp missing - under the new rules-
If I remove the airbags and the lamps then that might pass the MOT. But I am yet to confirm this.
