General Start of the headgasket today! :)
Orpington
Start of the headgasket for my 16v sporting!
Got the timing tools coming on thursday but starting to take everything off now!
Shall i still mark everything up? or is it safe to just pull everything off and time it up at the end of the headgasket?
Also, im lapping the valves when i get the head off, can i manually pull the valves out or do i HAVE to have the valve extractor? :)
Just an update :)
Cost me £170 so far to complete this headgasket! :( but its getting there :)
Melted the inlet manifold when it was overheating so i had to get a second hand one of them today! I took the head to a shop and they have said it needs to be skimmed, the limit marks were still there so its safe to :)
lapped the valves and polished everything up, polished the pistons, appantly unburnt fuel sticks to the deposits on the piston so buffing them up to all shiney cant hurt :)
Got the timing tools coming friday afternoon now :( but id rather do everything properly! Cant wait to start putting everything back together! my first ever headgasket ive done lol! :)
Just an update :)
ive seen 2 melted manifolds this last 12 months causing all sorts of problems this is why i keep telling people on here to invest in a vacuum gauge because the reading would show as nearly 0 if you had it running and connected
keep us posted and remember to take some photos
everyone like a photo:)
Whats a vacuum gauge mate? Sorry not really technical when it comes to this sort of stuff lol.
Quick (and possibly silly) question...
As ive had my head skimmed twice, have i got to tighten the headbolts up even more than the:
30nm torque
Slacken 90 degrees
90 degrees
90 degrees
Or shall i just go this and it should all be ok? It seemed when i did my last headgasket the bolt were really hard to tighten up but getting them off was sooo easy!
Just curious! Thanks :)
30nm torque
Slacken 90 degrees
90 degrees
90 degrees
no and where did you get that instructions from?
use a dial gauge you will be surprised how much more than 90 degrees the drive has to go to turn the bolt end 90
damm, i just bought a torque wrench which you set it to untill it clicks :(
ill move the bolts a little more than 90 degrees then shall i? really cant afford another tool... lol
you need a torque wrench too, dial gauge is only a fiver. i'm more worried about the method you have posted, where did you get it from?, ive always done torque, then 90 then 90 again, never slackened, just the 3 stages
It says it on the instructions i got with the new headgasket :s
Ive always thought it was
30NM
Tighten 90 Degrees
Tighten 90 Degrees
But it says here to slacken before tightening :s weird lol.
might have to invest in one then! Last thing i want is this headgasket going a third time in 7 months lol
Just finished the headgasket, without too much cursing! haha
Timed it perfect! Done everything by the haynes manual, started it and it was ok but seems a bit hesitant... plugged in the diagnostics and its come up with 7 codes :(
P0202 injector circuit Cylinder 2
P0135 02 sensor
P0340 camshaft position sensor A
P1135 (undefined)
P0130 o2 sensor
U1702 (undefined)
P1314 (undefined)
.... help :(
