Hi Friends , I have a Punto 1.3 year 2001 , since some time ago the engine lamp start lighning ,
I checked last days with a OBD II reader and got OBD Code P 1135 (Preheeting resistance 1 above Cat) is what my OBD reader indicates,
I figured out by reading here at the forum that it could be the Lambda Sond that is faulty , I started replacing the first ( the one before the cat) without any result the code P1135 still coming back also after cleaning the code, then I also changed the second Lambda sond after the cat and code still comes back , ( after changing the second lambda sond i think that the code P1135 is coming only when the engine is cold , but its keept in the memory ,
I do not have any more idees what can be wrong , for me it sounds like something is wrong with the pre heeting part but i´m not sure,
I should mention that the 2 lambda sonds i changes was universal type 4 wires that i used , ( not original or Bosch)
Can the problem be the Cat ? or are there any other compoments involved for the pre heeting ??
Please advice i´m stocked in how to continue
regards Kostas
regards Kostas
