jessiegilbert
- Nov 1, 2011
- 2
- 1
Hi, just wondered if anyone can help. I've already had a look at similar threads, but nothing is quite the same.
I've just got a Fiat Punto Y reg. It's just passed it's mot, with a few advisories to do with the brake pipe and hose.
Anyways it is running fine, no knocks or anything. The first day I had it the battery died, but I thought this was due to it sitting idle for a month.
Since this, the engine warning light keeps going on, it's not flashing, it stays on for a day, then goes off for a day.
The car is running ok, except it cutting out twice whilst sitting idle, but it started back up no problem. No other lights are on and it seems to be running fine.
Does anyone have any advice please. I have read it needs to be plugged in to have the codes read, but I've also seen disconnecting the battery can clear these if everything is running ok.
Thank for your help it's much appreciated.
