I'm new to the forum and in need of answers, so I apologise if this has already been covered somewhere else. I've just bought a W Reg Punto, and it appears to be a little bit broken:
1. The engine shakes, sounds like it could be backfiring
Backfiring is when unburnt fuel is given enough heat to ignite, the engine shaking and knowing that punto's are known for mis-firing its a good chance either a Plug has given up, the HT lead is earthing instead, or the other well known Coil Pack issue
Start with Plugs and leads, as there cheap and easy todo, then if the "shaking" dont stop its next stop coils, again there not too expensive, and its all DIY stuff
2. The car is very unresponsive in terms of gear and speed - it does about 50mph in 5th with foot to the floor
Links to No1 really, its asking you to run with only 1 leg, sure you can do it, but no way near as good as if you had 2. I would guess sorting one will sort this one too
Remember tho 4th and 5th really aint speedy gears, there cruising gears, yes the car works hapily in them tho, but as said consider point 1 before looking at this issue, as they are linked in my eyes
3. The engine is over heating (maybe as a result of 1))
Now, when you say overheating, You mean the Overheat light is on?
eitherway, check there is Fluid in the Coolant Bottle, as lack of fluid is why the car overheats, but when you consider point 1 2 and 3 all together, its looking like a possible HG
Get the Cooling system Fully Refilled, Bled up and see if fluid is been lost and if the OVerheat has stopped, however if the HG has gone, the Overheat will come practically straight back along with the miss-fire and no performance
4. The fuel I put in the car to cover driving it back seemed to disappear. Approximately 4 litres of fuel seems to have been used within a 12-15 mile drive.
Roughly that means you doing less then 12mpg, which for the punto isn't good
even when i have my hammer foot, i averages 32mph, happily running i can get upto 50mpg but that never lasts, i regulary cruise around 40, but every car is different
However fuel going nowhere has 1 of 2 options
1 - its pissing out onto the floor
2 - the engine is burning it, now this COULD potentially lead to no1, no2, no3 as well as this, the Lamba sensors are overfueling the car, now when they fail too much fuel is put into the cylinders, as a result you can actually Mis-fire due to not enough air in the air to fuel mixture ratio. it would also explain why you are getting poor economy
its abit hard to target which one really is at fault
Start with the Cooling system - get it filled and Bled up
Overfill the Coolant resivoiur Open the radiator Valve, and squeeze the bottom rad hose, if water gush's out then no air there, if air does escape, hold the pipe, close the valve, and relase your hand, you should head the Cap on the Rad suck air in = good
Repeat till the Radiator Valve lets only fluid out
But keeping an eye on the water level
Same again for the Rear Bleed valve - open - squeese - close - release
Till All the air is expelled and only fluid escapes
make sure the fluid level is at max, or just sligtly over
Run the engine, wait till the fan kicks in
if the engine overheats - Switch off, you dont want to stress the head, but the damage may have been done from the previous overheat
When its cool see if there fluid still, if its gone
it says why you have a mis-fire, the overheat as well
But if that remains fine, i'd be probably looking with FIAT ecu (free edition) scan and diag cable, see what the ECu says the voltages for the lamba's are
0.1 is VERY lean
0.5 is Spot on / good mix
1.0v is VERY RICH
Anyway i'm going to stop rambeling now and let you get on with bleeding
Any help/advice would be greatly appreciated - particularly if it involves little or minimal cost.
