Depends entirely where the oil is. If it's on the electrodes, bad sign. If it's on the threads, means little. If on the insulator (top) either leaky rocker gasket or clumsy with oil refil.
Compression test will reveal all. Disconnect the TDC sensor (aka crank sensor) to prevent the engine firing. Throttle full open.
