The missis' engine is absolutely knackered and I'm going to change the whole lot as it's not just the head that needs attention.
So I've been looking a bit online to find out which engine fits correctly
There are four variants.
(1) (2000 - 2003), 1.2 Petrol Engine, 16 Valve, with AC, with the cam sensor on the rocker cover
(2) (2000 - 2003), 1.2 Petrol Engine, 16 Valve, without AC, with the cam sensor on the rocker cover
(3) (2000 - 2003), 1.2 Petrol Engine, 16 Valve, with AC, without the cam sensor on the rocker cover
(4) (2000 - 2003), 1.2 Petrol Engine, 16 Valve, without AC, without the cam sensor on the rocker cover
The engine in the punto currently is number 4 , without air con and no cam sensor in the rocker cover . So I know what I'm looking for but I just wondered why I cant get any of the other engines, let's say I get a engine with air con and cam sensor in rocker cover. Can I not just leave the cam sensor blocking the hole up in as there will be no wiring for it. And unbolt the aircon unit and use the appropriate aux belt?
Also I can't find any way of releasing the pressure from the fuel pump. Is there a way to this manually or is there some sort of valve the self releases the pressure?
Other than that I'm ready to tackle it
