Thread Tools
Old 19-07-2011   #1
Strange Overheating
My Mk2 punto recently (2months ago) had a HG change after overheating, skimmed the heads and replaced timming belt, thermostat and HG. Since then I have occasional error codes comming through. Cam position sensor and throttle position sensor error codes, but not all the time. These dissapeared when I replaced the cam position sensor and the throttle body. ...
Yesterday, after driving perfectly for a week, the car wouldnt start. It had been left for 45-60mins while I went shopping. The engine was still really hot, so i took the air filter off and withinn 20mins the car cooled down and would start. Same problem today, really hot after 45-60mins of doing nothing...
Any ideas??? Temp gauge reading fine, fan working fine, coolant correct level/concentration.
Oh, and I found a connecter just dangling. It was hanging from one of the wiring looms leading towards the ECU????
Please Help?!?!?
Likes Moimo liked this post
JShallis is offline Reply With Quote Quote
Old 19-07-2011   #2
Re: Strange Overheating
Can you take a photo of this connector hanging loose?
gavinh87 is offline Reply With Quote Quote
Old 19-07-2011   #3
I will do as soon as i can find my camera dock
Old 19-07-2011   #4
Photos attached, couldn't work out how to add them directly to the post...im not a computer person :-(
ID:	92756   Click image for larger version
Old 19-07-2011   #5
hmm just took a look at mine and it looks like i dont have one :/ I would say it goes to the throttle body/inlet manifold though judging by the length of it
Old 19-07-2011   #6
my thoughts exactly, but the mating surface doesnt match any of the connectors...strange...any ideas on the overheating?
Old 19-07-2011   #7
Tony123 has donated!
Choirboy Champion
is that the temp sensor plug ?
Tony123 is offline Reply With Quote Quote
Old 19-07-2011   #8
I would say yes temp sensor, especially as its overheating. It should be next to your thermostat housing.
Old 19-07-2011   #9
Im struggling to find where it would go?? No plugs?
Old 19-07-2011   #10
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
My Green Box's
You can see 1 connector there - weather or not its occupied or not
And there is just one Visible just behind and lower then the Rear Bleed Screw
As for Temp sensor - Temp sensor said to be working
plus he'd have error code for Temp Sensor Malfunction
AND no power as the car would be running rich and the fan would be constantly on
ziggy
Edit - Another weird Thought - do you have your Reversing light working?
If so it could be that but there must be a plug that your missing somewhere
ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 20-07-2011   #11
I'll check the reversing light, thanks ziggy
Old 20-07-2011   #12
The reversing light works fine...
Old 1 Week Ago   #13
Did you work out what this was?
I have the exact same cable loose after a head gasket replacement.
aidander is offline Reply With Quote Quote
Old 1 Week Ago   #14
flisko's Avatar
flisko has donated!
Quote Originally Posted by aidander View Post
you sure its not butterfly sensor?
flisko is offline Reply With Quote Quote
Old 1 Week Ago   #15
I will check this tomorrow, it appears long enough and if so is currently obscured by the air intake.
Thread Tools
(T) very strange one this Tony123 Punto (Mk2/2b) 8 14-04-2011 20:41
(G) Strange? ShaunMck Punto (Mk2/2b) 1 26-11-2008 12:28
i am strange Captain Mike Leisure Lounge 0 17-04-2008 23:31
