lightrider
Hi. I had this in "tech talk" but mostly met with tumbleweed. I'm entering phase 17 of getting my car sorted so I'm hoping for a little help here if anyone's got some wisdom for me please?
My dualogic gearbox doesn't like changing gears. Initially, the car had trouble engaging reverse. Sometimes it would falter during some other gear change and need restarting. It often would not engage a gear when changing up or down, defaulting to either neutral or clutch open. The only way to get going again is to turn the engine off and restart it. This usually works, but not always. Warning lights and beeps come on, and the dash sometimes says "Gearbox Fail." or "Gear unavailable" but the only errors the examiner has read are "Gear change control" once and "Fuel level signal" once.
An end-of-line service using an examiner fixes things for a while and the reverse problem hasn't (yet) come back. After end-of-line services the pattern is that the gear changes get increasingly unreliable until the end-of-line puts everything right for a few days. The mechanic explained this as overcoming a reluctance learned by the ECU upon meeting resistance during gear changes.
On first testing, the pressure in the accumulator seemed ok at 45-48 bar. The pump sounds like it's working fine with a 12-15 second whine initially and then a few seconds every few gear changes. The battery showed 13V. The car has about 47000 miles.
The car has now had a thorough maintenance of the dualogic/selespeed system: oil level, clutch retrain, sensors cleaned, cpu reset, and whatever else the mechanic got up to that I can't remember. It sounded thorough and it was done by Paul at Motormech in Birmingham and he's got a good reputation.
After this maintenance it drove beautifully (less gear clunk, no problems) for about 150 miles. Then the problems started again. The biggest problems are from 5th to 4th (engine must restart to drive at all) and 2nd to 3rd (refuses 3rd after engine gets hot and seems ok after engine cools).
So: gearbox knackered, do you reckon? Any other possibilities before replacing/fixing it?
If it's the gearbox, replace? Recondition? Is the gearbox on diesel dualogic the same as on the manual version?
Another problem that may or may not be related is an error in the radiator temperature/fluid level. It comes up as an error on engine start but the coolant is fine, and so is the temperature. I suspect a sensor fault.
Any help will be much appreciated!
