- Apr 15, 2011
- 22
- 5
Hi all,
I have a 2001 1.2 16v Fiat Punto HLX, and I am having a few problems. Firstly, the car struggles to hold an idle (in the sense that it is *very* rough). For the last few months the car had been cutting out as I approached a traffic light in neutral, and sometimes cut out as the revs often dropped to around 600rpm. I am unsure if the problems I am having now are symptoms to the problem cutting out I faced previously.
Also, when I drive - there is a tapping from the engine (this is only when the car is under load, or if I run through the rev counter quickly). The tapping is not too bad when revving, however it is very noticeable when driving (which I am not doing, just saying to help the diagnosis).
I have a cheap OBDII tool, and there was a P0105, referring to the MAP sensor. I replaced this, and it has made no difference. Due to this, I would assume that there is a problem either elsewhere in the circuit, or the fuel:air mapping is having problems elsewhere. There is also reports of misfires on cylinders 1 and 2, however when checking the spark plug ends they're dry (however, blackened). The car is running rich.
I have tried to check the timing belt, and it seems to be in excellent condition, and seems very tight - is it still possible for it to slip while tight?
I also removed the pre-cat (upstream) oxygen sensor, and tested it by placing a propane torch onto the end of the sensor while reading the output with a voltimeter - it seemed to react quickly. Could it still be a lambda issue?
I am struggling to find the issue, however I am no mechanic and I hope that somebody can help point me in the right direction.
Many thanks in advance,
Chris
Chris
