if its never had a cam-belt its due for one, however its a Nice 8v
Safe Engine
So depends if you wanna have the Belt done soon or not
usually they say every 4 years or if you reach 64k Mark and never having it done
*If belt is been done, a New Water Pump and Belt Tensioner go on as well, there like hand in hand, its no more extra labour, as the pump has have the belt off anyway*
Abit more expensive, price up your cars needs on Shop4parts
Plugs - should still be good at 6k old, thats IF they were replaced in the last service
If the plug weren't then the HT leads weren't, They go hand in hand tho
DIY = Its easy really, plugs are about £4 ea, and HT £15 i think
Oil and Oil Filter, is easy DIY, 6k isn't long, but depends if its black or not, if its black it probably means your ready for a change
DIY= Easy peasy, Just need the tools really, about £5-8 on filter, and £20 on Oil
You could put a Flush in there with the old oil, help clean it out, there about £4
Airfilter - Cheap as chips, Get it done
DIY = No more then a £5er
Anti-freeze, a good Radiator flush, (might wanna stick a hose pipe in the Heater Matrix hole as well, as that'll hold LOTS of Old Anti-freeze, flush it out till the fluid runs clear like water
and a refill with Red OAT 5 year Anti-freeze mixed 50/50 (probably best putting conc in at first, as said above, alot still sits in heater-matrix which wont come out
Diy = £15 - £25 i would have thought, depends how much Anti-freeze you buy and the flush, you will also need a new Clip for the bottom radiator, as you have to mash the old one off to release the pipe
As for the MOT, drive it like you stole in a few times before it goes in, and when you do go for the MOT, give it them nice and HOT
Hot as possible, its a way to prevent you getting an emmisions fail
DIY = No different to normal, you could stick a Cleaner again in there, as it might help Clean the engine out, about £7max i believe
Thats the engine done really the Mot dont just look at the Engine tho, as your aware
Checking your lights work - DIY
Tyre Treads Decent = DIY
Brakes, takes abit more time, make sure there is decent meat on the pads, and the Disc's aren't too heavily scored / pitted / blue
Rear drums, Check for meat - and adjustment and the Lip on the drum, if the lip is deep, you might be ready for new drums, but at 04 i'd of thought they'd still have life in them
i only replaced my drums at 9 years old
Check for Play in other parts, like bushings and Bearings
If they car is generally good health, they usually fly through the MOT
ziggy
