Hi, I know someones already asked about wheel trims but by problem is that when i bought my car it only had basic plain halford wheel trims, because i can't afford alloys i wanted some decent Fiat wheel trims as an alternative - the garage wants stupid prices ie £34, so i've been looking on ebay where i've found a set of wheel trims - the ones that come as standard on a new punto from fiat. Only problem is i'm not very mechanically minded - and these trims (if you know the ones i'm on about) are the "bolt on type" (4 bolt holes in the middle) i asked the seller about it a he said it should be fairly easy to fit (just take bolts out, trim on, bolts back on) which i fairly straight forward - but the problem is he said that i might need to buy special bolts to do it but he wasn't sure. Can anyone tell me if this is true or shed some light on the subject. Do i need special bolts??? Help, thanks.
