Hi anyone have any ideas, i have a punto mk2b 1.2 8v, recently had a recon gearbox fitted, problem was 5th gear was not in correct place, so took it back to garage and they sorted, told me they did not set up the gear linkage correctly when they did the gearbox, when collected the car the said they have fixed problem but it may do it again as the gear cable is rearly stretched, had car back for a couple of days and noticed recently when in 5th gear it keeps popping out, mainly when on a slight inclimb while accelerating, i dont have any faith in this particular garage, but when they changed the gearbox would it of been possible for them to of fit a different cable like the one that came with the recon gearbox, as i find it strange that I never had problems before they fitted gearbox with gear lever popping out of 5th into neutral?
Any help would rearly be appreciated as I am calling the garage again tomorrow, my point is they have repaired my car but not correctly and I am worried they will try and charge to sort, it went in for a recon gearbox but has come out not being drivable, I am also thinking about getting trading standards involved as it has not been rectified!
Any ideas????
Punto has only done 38K miles, I am second owner and is fully serviced and driven afew times aweek!
Any ideas????
