Broken Foot Brake Switch
Not something that goes - but its fairly easy to sort
Stick your head under the Driver footwell - look at the brake pedal - you will see a Small White / Brass looking switch - its quiet small
As you press your brake - a little shaft drops down as the pedal moves - As the switchs Button if you wanna call that then completes the circuit
its basically a Push to Break Switch
Ziggy
