when you start the car first thing it takes about 5 times giving it a bit of throttle when you turn it over it turns for about 10 seconds then stops like you are advancing the timing its had new plugs ht leads lambda sensor read the codes and they are as follows p0340 camshaft position sensor a bank 1 circuit malfunction u1602 definition not none any ideas cheers Paul
