I have a punto 1.2 2001 reg and it has just had the head gasket changed.
Then it gradually but quickly developed another fault with the engine light code set to on so I bought fiat scanner and elm 327 to read the code.
it runs v.poorly
the code
p0352 - ignition coil (3)
explanation given is software is [ ECU ] received very low signal from sensor!
I don't understand.. what sensor?
With the engine running I clear the fault code and for a few seconds it runs fine then the code re-appears and back to running rough. I presume its shutting the injector down to protect the cat.
I have changed both coil packs and swapped them over with no avail.
I have changed plugs with no difference
I have but the spark tester on each and they are sparking fine
If I am taking the software's words literally its talking about a sensor with a low signal to the ECU but I cant think what this could be/mean
I have read about the ecu's can go down but I have checked the signal at the coil end and it appears to be fine ( 12v constant signal and pulsating negative switching signal )
I don't understand what could be causing this problem so hoping somebody could give me ideas or maybe its something you have come across before that you have fixed?
Thanks for reading I so hope you can help its driving me mad and I don't want to be spending money that I haven't got...
I promise to donate if the answers lead to its fix!
it runs v.poorly
the code
