tyronehowe
- Nov 22, 2010
- 3
- 1
Hi Everyone
My daughter has recently bought a 2001 Puno 1.2. The car is excellent except the fan heater isn’t working properly. I have read a LOT of posts on this forum about very similar problems but I have tried to fix it but still it’s not working. Here is what’s happened:
1) The fan heater control stopped working – it was just a smooth movement from 0 to 4, no “click” on the numbered positions.
2) Purchased a second hand replacement on eBay. Tested that the four positions of the fan closed circuit between the 5th connector and each of the other four connectors in turn. Installed it.
3) Fan heater still not working.
4) Thought it might the resistor, but after tracing through the wiring (and reading lots of posts on this forum), it seems that the resistor is not used when the fan is on maximum. Tried the fan on maximum – still not working.
5) Checked for the earth problem with the connector before the motor – no problem.
6) As far as I can see, it is the earth connection that is switched through the resistor (except when the fan is in position 4 where the earth is directly connected to the fan). I have checked with a meter, and the other connection to the fan is NOT 12v, it’s nothing.
7) Checked the 7.5A fuse in the fusebox next to the driver, and it’s fine.
8) Changed the heater fan system relay with the Electrical pump system relay and still not working.
So I am stumped now. I can’t think of anything else that would prevent power reaching the heater fan.
Any help, advice or ideas would be very much appreciated!
