Technical Power Steering Warning Light
MrsGiggles
Newcastle upon Tyne
Hi Guy's and Gal's,
Driving along today, and the power assisted steering failure light came on, and stayed on. :eek:
The power steering felt fine, no different. :confused:
Now usually I would panic, but, about this time last year, in the same cold and wet weather conditions, the same thing happened with the power assisted steering failure light. I took my Punto to my local garage, the mechanics took 'her' for a spin, and no warning light appeared, and infact the warning light did not appear again until today.
Now I know my car does have it's own 'eccentricity's' which FIAT's are renowned for. I am also aware of FIAT's detesting cold damp British weather, so I wondered if it's condensation on the electrics that could be causing this?
So, has this happened to anyone else? Can this be explained, or do I have another mysterious electrical fault.:cry:
Kind regards to all.
Faye and "Lily-Rose"
The EPS failure light can come on from a stall?
But its more often realted to the Battery been to weak / Too Cold
Again yes it could be cold playing up too
If the steering is still working, it means city wont work, and a minor malfunction has occoured
As to what caused it - you have to get the fault codes read
Ziggy
