Hi
I have an MOT problem with my punto, it is showing following readings for emission
CO 9.96% should be 0.3%
HC 740 ppm should be 200
lambda 0.72 should be between 0.97 and 1.03
The garage has asked both catalytic converter and sensor to be replaced at a cost of about 500, I want to know whether these readings suggest a definite failure or something can be done to tune? also are both components failed ?
The car had a fault code P0130 recorded in fault code but EMS light is not on now.
The car drives OK and has been recently serviced as well.
