yorkshiretight
- Nov 20, 2009
- 9
- 5
I'm in the process of replacing a blown engine (1.2 16v) with one that is not. Original is still in the car but stripped to piston level. The manual suggests that to remove the engine the gearbox and transmission has to come out too as a single unit.
I'm thinking I can split the block off from the gearbox leaving the gearbox supported and winch out the block.
Anyone got relevant experience they might like to share?
(Incidentally for anyone venturing down into the depths of their Punto engines, as above, don't be mystified by the fact your metric spanners don't fit the engine Earth strap or 1 out of the 3 large bolt heads that hold the alternator in place. That's because fiat seem to have had an outbreak of Imperial sizes, the earth strap is 1/2inch and the odd alternator is 5/8. Odd don't you think?)
Cheers, Chris.
Cheers, Chris.
