Technical radio -'wait' message-help!!!
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
Did the radio display show " CODE " then " - - - - " immediately before you entered the code?
The CANCHECK message can show because the CAN (Control Area Network) wires haven't been connected to the radio, or because a radio from a CAN equipped car has been fitted into a car without CAN.
Hi mate sorry the cd player came out of my friends punto and I put it into mine. Does that mean the cd player wont work then?
as davvy says and i tried to explain depending on spec of your car and age other radios from the fiat range dont always work
its like trying to put a rolls royce radiator in a mini
the radiator would cool the mini but it wasnt designed to block your view:D
thing is for a £1 you can wang it on ebay cheap and i might buy it:D;)
Davren
I am having the same problems with my daughters radio in her Punto. I left the ignition key in, turned on for two hours, switched off the radio and switched on again but it was still the same. It has 'wait' on the radio screen and I am running out of patience with it. Any ideas?
Waiting time depends on how many times an incorrect code has been tried, and could be up to 24 hours as it the table below.
The radio and ignition needs to be left on continuously for the waiting time. If you switch either off too soon, the waiting time starts again.
attachment.php
Thanks Davren. There seems to be a bit more to this than first told! This happened when my daughter went to turn on the ignition having not used the car all day and found it said 'code'. She then pressed menu without really knowing what she was doing! (It is her first car and she only got it two months ago). Thats when the word 'wait' came up. We have the code so thats not a bother. I just want to know how to reset the damn thing!
I look forward to yours or someones response :)
Re: The one and only code for fiat radio thread.
Help..!!!!
H
Can someone please get me a code for fiat punto radio
815 BP237536858842
7 642 375 316
Please its my daughter car and she is going mad with no tunes..!!
Help..!!!!
H
815 BP237536858842
7 642 375 316
I have answered this on one of the other threads you've posted it on.
Please do not spam the forum with duplicate posts on multiple threads.
Hi, can anyone help me in gaining a code for my punto blaukpunt radio? My car battery died presumably resetting the radio, I have found 2 codes I found on the radio itself
BP-NR. 7649372316
Prod. Nr 735 289 639
Many thanks
Hi there, can anyone help and advise on how to enter (0) with a standard blaupunkt radio which i in a fiat ducato, i have my code but obviously i cant see how to enter this when all i have is presets 1 to 6 so i assume another button is used?
Many thanks in advance
The standard Blaupunkt radio fitted to a Ducato will have a code from 1111 to 6666 only. I suspect you've been given the wrong code.
If you post the radio's serial and part numbers, I'll let you know if I can get the correct code for you.
Good afternoon,
I have a Fiat Sedici . Now my car is already asking `s three weeks to help . Apparently I must have received a code when purchasing the car but because we are the second owner was no code bij.Maar now doing my radio and I have nothing and need code .
Here some data
Id No. 39101-79JB
Model No. 39101-79JB0 -CAT
Ref no CQ- MX0674G
Type: PACR06
Serial No. 184 108
I hope you can help me know my
Thanks for the effort
Good afternoon,
Here some data
Id No. 39101-79JB
Ref no CQ- MX0674G
Type: PACR06
Serial No. 184 108
You may be able to get the code for this Panasonic radio from a main dealer. If not, then it can only be decoded at a car radio workshop.
Hi there I have purchased a 2006 fiat panda . The radio just says wait all the time. The vehicle didnt come with a radio code. Could someine help me please??
Make is dolby
Bp7643389316
Prod.nr.fiat
735403207
Thanks for any help
Make is dolby
Bp7643389316
Prod.nr.fiat
735403207
Thanks for any help
Wait means too many incorrect codes tried
I believe wait requires 3hrs without been touched and itll reset
Ziggy
Make is dolby
Bp7643389316
Prod.nr.fiat
735403207
Thanks for any help
I need the serial number. It will be stamped into the side of the radio and be something like BPx389xxxxxxxx
there is no other bp number on the side.please see photo. this is all it says on the radio. Thanks
