Technical Punto mk2b airbag resistor
Hi guys! I recently removed my standard steering wheel with airbag and installed MOMO wheel with hub. Since airbag is removed, red notification is lighting in the dash now. My question is can I install some resistor at airbag connector to trick ecu that my airbag is still present? Did anyone tried something like that? Cheers!
^that`s what I did after installation but I guess that since airbag light is on, the passenger airbag is not working also. Am I right?
Correct any problem with the airbag system then the airbag ecu will be disabled for safety and will need resetting before the light will go off (after 'fixing' it)
I know that but first I must solve the problem and trick ecu with some resistor which will act as a regular airbag. People are doing that on other car forums with different resistor values (depending of car model) but no one did it in fiat punto :)
When you measure the resistance of airbag, it shows 0 ohm, probably because of coil inside. The solution is to put 3.3ohm 1/2W resistor and it will act as airbag. After that, airbag fault code must be cleared and it will be ok...
I have a mk2 punto when i took out the passenger chair the airbag light came on i went to maplins and asked for a resistor wire for my punto i showed him 1 on ebay he said yes he you go now it works well
i feel sorry for people who remove airbags
They are there for a reason
SAFETY
By bypassing - you are risking either yours or your fellow passengers (Mum dad best friend - dog - sister - Mother in law who ever)
Also
Are you notifying your insurance company of the airbag removal/Bypass?
Because your disabling a safety feature, they will want to know - cause your more of a risk from serious injury
Also
NEVER EVER!
NEVE EVER EVER!!
Stick a multi-meter ACROSS THE AIRBAG TERMIANLS
you are asking for trouble..... airbags only need a tiny static / current / voltage to detonate them
SO ALWAYS be careful with them
Ziggy
