Does anyone know the internal diameter of the bottom coolant hose on the MK1?
I intend to fit a proper header tank with a t-piece in the bottom hose to a small translucent plastic tank on the bulkhead as high as possible; also thought to connect a t-piece into the coolant hose going to the throttle body and run a pipe into the top of said header tank so that the system will self bleed. Can anyone see any problems with this idea?
