pmcq said:Hello!
Anybody ever changed the rear brake shoes on a 96 punto ? Just wondering how long it takes and if there are any things to watch out for?
Cheers,
pmcq
Take some pic`s as you remove them.
Makes replacement a bit more easy.
As said, two types of make for this car so double check before you buy.
This was solved by replacing both the rear brake cylinders (Tot. £27.50 from a motor factors) as one of the bleed nipples had been broken off by the previous owner. The brakes feel much better now but the brake warning light has come on at all times. Any suggestions?I have never seen a car with only one bleed nipple at the back. Each should have their own.
Thanks Bernardi, I have checked the connector under the master cylinder and ehsured it is topped up with brake fluid but the warning light stays on?Check the level in the master cylinder and the push-in connecters
