- Sep 9, 2015
- 200
- 44
Ill check with motor removing and let you guys know the result. This is the code I am getting C1008 motor phases https://www.fiatforum.com/punto-ii/343008-steering-ecu-low-voltage.html . See his attachment also same as mine. When key is on I can see the both voltages nearly same but after starting the engine the red steering light comes and voltage drops at ECU supply pins. What is this ECU supply pin? I guess not the high gauge white/red and black supply wires/pins. My garage said need to replace the torque sensor or the complete column. They have a common every car scanner and showed the code DTC 5008 (As I know this is same as C1008). This is the first time I was unsuccessful troubleshooting my punto
Hi I tried with alfaobd see the results it says system disabled. so how to enable this.
c1008
Motor phases
Open circuit
Failure lamp 'ON': Requested
Fault present
Test complete or not applicable
Battery voltage: 11.73 V
Recovery type: System disabled
Effort on steering wheel: -0.14 Nm
Vehicle speed: 0.00 km/h
Calculated steering position: 0.00 °
Motor control current: 0.00 A
