Old 10-12-2009   #1
Get a wriggle on!
levemircento's Avatar
levemircento has donated!
Question top steering column bearing/bush
got some play in top steering column bearing, looking on eper its described as a "resiliant bush", see pic below
is this a fiat dealer part? are the prices on eper the actual prices?
is it hard to replace?
its a mk1 1998, no power steering
must be time for a brew
levemircento is offline Reply With Quote Quote
Old 10-12-2009   #2
Trader Rating: 5
fingers99 has donated!
Re: top steering column bearing/bush
If you've access to a lathe and are happy to estimate the tolerances, you can almost certainly make them up. Otherwise, it'll be a FIAT only part.
Never done it, but I suspect you drift them out from the opposite side, press back in.
AFAIK, ePER is accurate if it's an on line version: you might try Fluffy the Impaler or Shop4Parts.
M12 fund £20
fingers99 is offline Reply With Quote Quote
(T) Front uppershock absorber Bush and bearing kit glenndaleuk Barchetta 1 11-06-2009 14:47
(T) rear shock top bush antsuno2 Uno 15 09-09-2008 13:08
(T) Steering column top bush jezzer Barchetta 3 28-03-2007 19:38
(G) steering column bush kit thefishdude Punto (Mk2/2b) 0 11-10-2005 16:36
(G) steering column bush thefishdude Punto (Mk2/2b) 0 04-10-2005 15:07
