Old 02-12-2009   #1
I like to be different!
bredsticz's Avatar
Trader Rating: 1
bredsticz has donated!
Engine rebuild
How much will an engine re-build cost on 1.2 8v mk2?
bredsticz is offline Reply With Quote Quote
Old 02-12-2009   #2
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Engine rebuild
123 pounds 18 shillings & 6d
Come on fella... DIY just the parts? Full re-build...? half engine, professionally done inc VAT? Do some phone calls....
Oh do some phone calls to engine re-builders
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 02-12-2009   #3
Geek of the Week
smokeyjoe03's Avatar
Trader Rating: 1
smokeyjoe03 has donated!
Aniki Pingpong Champion, Rat Zapper Champion, TIE Fighter Shooter Champion
Re: Engine rebuild
Quote Originally Posted by bredsticz View Post
Possibly more than another mk2 1.2 8v?
smokeyjoe03 is offline Reply With Quote Quote
Old 02-12-2009   #4
Re: Engine rebuild
Assuming you mean from top to toe (cylinder head skim and new hg , shims etc,piston rings , rebore? crank bearings etc etc etc and quite a few hours labour i think you d be lucky to see change out of a £1000 and possibly more.
Just a guesstimate(and could be widely off the mark) to give you a starting ball park figure)
If your mk 2 has gone belly up a low mileage replacement engine is really the only ecenomical repair when car values is brought into the equation.
Richc64 is offline Reply With Quote Quote
Old 03-12-2009   #5
Tony123 has donated!
Choirboy Champion
Re: Engine rebuild
you may as well fully mod the engine if yo gonna rebuild.. may work out cheaper
2001 Abarth Fiat Punto HGT for sale
http://www.fiatforum.com/members-mot...rcy-punto.html
Tony123 is offline Reply With Quote Quote
Old 03-12-2009   #6
Trader Rating: 5
fingers99 has donated!
Re: Engine rebuild
If it's "just" for normal, everyday use, swap out the engine for a known good one or something bigger and better (see the 1.4 16v swaps on the Cinq/Sei forum). Or, if you can do most of the work yourself, a simple refresh can be relatively cheap.
Otherwise, you can build something faster and stronger than the original unit, but it'll cost.
M12 fund £20
fingers99 is offline Reply With Quote Quote
Old 03-12-2009   #7
Banned
karbineftw has donated!
Re: Engine rebuild
Quote Originally Posted by fingers99 View Post
Wouldn't other things be required though? newer engine loom, gbox, brakes and etc?
karbineftw is offline Reply With Quote Quote
Old 03-12-2009   #8
Trader Rating: 5
Re: Engine rebuild
You'd need a different ECU, maybe aftermarket, although a 1.2 16v could be reprogrammed to suit. Get the 1.4 16v gearbox (we're talking the Stilo/Grande Punto/etc motor), Punto GT front calipers and disks. Usual attention to suspension, wheels, tyres.
Probably all doable for less than a "fully" rebuilt 1242 8v.
M12 fund £20
Old 03-12-2009   #9
bredsticz's Avatar
Trader Rating: 1
Re: Engine rebuild
Thanks for the replys, just looks like piston rings have had it and the cylinder head needs skimming. Possibly rebore. I have no idea. Had a headgasket change in may and obviously was just a bad job! should have never bought the car. Now i have 2 puntos worth nothing! and can't put a bigger engine or mods due to insurance prices! I'm already paying about 1000 on insurance! thats not even fully comp
Old 03-12-2009   #10
Trader Rating: 5
Re: Engine rebuild
Try the FF scheme -- pretty good prices.
M12 fund £20
Old 03-12-2009   #11
Banned
Trader Rating: 3
Brin has donated!
Re: Engine rebuild
Is it possible to drop a 1.8l HGT engine into my 1.2l 8v PUNTO MK2
Forget about prices...
If i get a HGT engine, gear box and ECU could i drop it in and will it work or will it rip my punto to peices.
BTW do engine rebuild yourself punto 8v engines are only small with the right tools its pretty simple just takes time, patients and effort.
Brin is offline Reply With Quote Quote
Old 03-12-2009   #12
bredsticz's Avatar
Trader Rating: 1
Re: Engine rebuild
I need the car 7 days a week for work. 80+ miles a day, so i don't have time or patience! also don't have the right tools. and I'd presume u need to upgrade the manifolds and such with the engine aswel but if you're replacing everything all that's left is the frame so should be fine
Old 03-12-2009   #13
Re: Engine rebuild
Just lifted my car today, the head was roasted and the compression was gone in cylinder 2 after 70,000 miles. its a 2000 punto, 1.2 8v, so got an 04 with 45,000 miles from a breakers, got the engine, clutch, covers for £200. Took it a test run and got back and the oil was leaking from the sump, and the old one wouldn't fit. then once that was fixed, when idling the car was revving itself and when i was revving the lights were flickering. Still like it, think it could need the errors cleared but not too sure, anyone know what could be wrong.
SeanD is offline Reply With Quote Quote
Old 03-12-2009   #14
Re: Engine rebuild
And the steering light keeps flickering but no heavy steering
Old 03-12-2009   #15
Trader Rating: 5
Re: Engine rebuild
Earth fault (maybe missed the gearbox earth?) and possibly over-tight throttle cable, incorrect or faulty vacuum connections to TB.
M12 fund £20
(Tu) Punto gt engine rebuild help smallpauliscool Punto (Mk1) 2 30-11-2009 18:37
(T) engine rebuild (turbo) gdrake88 Uno 5 27-08-2009 01:57
(T) UT Engine rebuild andysporting Uno 2 21-07-2008 20:21
(G) Brava 1.2 engine rebuild bluejohn125 Bravo / Brava 1 30-07-2007 09:23
(T) engine rebuild? custard Cinquecento / Seicento 5 10-06-2005 14:43
