General Punto Starting / idle problems
mr_craig
ggdf
Hi Guys
Punto MK2 1.2 8v 2001
Im having a problem with my punto on startup, it starts everytime no problem but the idle can is erratic,the problem goes if i rev it to death for 10 seconds. there is no problem with idle or power when driving normally, its just at startup, if you try and drive it from start without reving you can feel a dramatic loss of power then its fine after you have been driving 30 seconds or so. If i stop the car after its been running and start again it dosnt happen, its only if its been left more than a couple of hours.
I have changed plugs ,leads , oil , coolant , air filter, cleaned breather piper and gave the throttle body a spray of carb cleaner , all which have made no difference.
The first time i had this problem the car had been sitting for a week, it had never been left that long before.
there is no sign of oil in water or water in oil
Thanks in advance
The IM light has started to flash , I have just had the ecu read and got code
p0300. Anyboby any ideas
Ps - i have punto the old ngk plugs back in as the bosch multi were even worse, i waiting for a delivery of new NGk BKR5EZ
sollution 2
ignore my previous post as i,d had a few and didnt read it propperly sorry, its sounds like the choke if its only on start up or when left for a few hours, its automatic on your model so could be a censor or a bad earth, buy a haynes workshop manual (check it first for choke diagnostics) available in halfords or any car shops, let me know how you get on
Re: sollution 2
:ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
Aye, its bound to be a choke problem
SPD
Hi Guys
Thanks in advance
Never never never rev the car when cold.
P0300 is misfire, http://www.obd-codes.com/p0300, Possible coil pack breakdown.
SPD
