Thread Tools
Old 29-06-2009   #1
Punto Warning lights - what do they mean?
My Punto has started comup with three warning lights on startup - the yellow engine management light, the red temperature light and the red 'steering whee;' light (or whatever it's called. They stay illuminated for a few seconds after starting and then go out. They only started doing this the other day.
Does anyone know what this might mean? I've check the oil and coolant, and the levels are fine, and it seems to drive ok. Had a new engine management system fitted about 6 months ago.
Vorax is offline Reply With Quote Quote
Old 29-06-2009   #2
Trader Rating: 6
Re: Punto Warning lights - what do they mean?
If they go out then there's nothing to worry about.
EML could be a million and one things.
Temp light could be a dodgy sender.
PAS is a failed unit, could be a sensor or the motor.
But as said, if they go out then it's not an issue...
It could also be linked to a poorly charged battery.
Need alloy wheel spacers or bolts? PM me!
richie.guy is offline Reply With Quote Quote
Old 29-06-2009   #3
Geek of the Week
smokeyjoe03's Avatar
Trader Rating: 1
smokeyjoe03 has donated!
Aniki Pingpong Champion, Rat Zapper Champion, TIE Fighter Shooter Champion
I had a the steering light on my mk2 go on and off intermittantly for a few weeks. I was told not to ignore it as it would lead to worse issues later on. However I took the car on a good run out and it never happened again since.
Most of my driving is just short trips and the battery needed a good charge is all.
smokeyjoe03 is offline Reply With Quote Quote
Old 29-06-2009   #4
Is engine manegment the yellow light above the green dpped beam light? or what is this, every now and then when i turn my lights on it illuminates, but as above goes out, i guess nothing to worry but shouldnt happen really
My car thread: http://www.fiatforum.com/members-mot...o-mk2-elx.html
ozzy39 is offline Reply With Quote Quote
Old 30-06-2009   #5
Cool Re: Punto Warning lights - what do they mean?
Any idea why on our punto the oil light & yellow engine management light stays on when the ignition is turned off but goes out when the ignition is turned on?
Aggie is offline Reply With Quote Quote
Old 30-06-2009   #6
Sarcastic little bugger
EmmaM88 has donated!
Keep an eye on your steering light, just had steering column on my MK2 replaced and same happened on my 04 plate panda a few years back. I have come to the conclusion either I am cursed with power steering or is a very common fiat problem across models.
Past: 04 Fiat Panda
Present: 00 Fiat Punto
Future: 100hp
EmmaM88 is offline Reply With Quote Quote
Old 30-06-2009   #7
Geek of the Week
Trader Rating: 1
Yup the dual drive PAS has many issues across many models.
And as for the oil and engine lights, I thought these were supposed to stay on with the key in 'mar' position and then go off with the engine started. Mine does anyway.
Old 30-06-2009   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by Aggie View Post
disconnect battery 5 mins
Old 01-07-2009   #9
Geek of the Week
Trader Rating: 1
Sorry disregard my last post, I thought you meant the lights were on with the key in and turned and went out with the engine turned on.
Not that they were on without the igniiton on
Old 30-12-2009   #10
i am aobut to inherit a mk2 punto but the engine management light is on, and stays on throughout the drive. any ideas?
jonyid is offline Reply With Quote Quote
Old 30-12-2009   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Quote Originally Posted by jonyid View Post
Get it read. Your local autospark should have an Examiner clone.
SPD
Old 30-12-2009   #12
yeah it's my girlfriends one and she's gonna get it scanned by the person that serviced it as it has only appeared after she got it serviced
Old 18-01-2010   #13
My engine management light came on & i took it to get read & that was no help! went through a million different things spark plugs, ht leads etc turned out to be my cat. On the subject of warning lights my oil light flashes on and off while travelling any ideas?
ven is offline Reply With Quote Quote
Old 18-01-2010   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by ven View Post
examiner or any dsiagnostic code reader is only a guide,its foolhardy to believe everything it tells you! You have to prove the fault otherwise its only a guess.
a experienced tech would of spotted the downstream lambda readings and diagnosed a faulty cat straight away.
Thread Tools
(G) Airbag warning & child seat warning lights on red Punto (Mk2/2b) 7 18-08-2008 21:38
(G) Punto warning lights on without key? Herts Hillhopper Punto (Mk2/2b) 4 06-05-2008 20:06
(T) warning lights on 95 punto blackwaterpfc Punto (Mk1) 3 06-03-2008 09:55
(T) 2002 Punto - Dash warning lights flashing - help please Algi Punto (Mk2/2b) 3 28-01-2007 13:51
