Thread Tools
Old 18-06-2009   #1
tyre pressures
http://www.thetyrepressuremonitor.co...ures_fiat.html
The above website says my punto 1.2 8v shuld have
Fiat Punto Recommended Tyre Pressure 1.2i 8v 99 - Onwards 30 28 32 32the 1st two 30 and 28 shuld be front and rear respectively but are under a heading of "standard"
see below:
Type of Vehicle & Model
Age of Vehicle (Year)
PSI Pressures / Monitor Required
Standard
Loaded / Speed
Front
Rear
Front
Rear
I do not know what "loaded" or "speed" means in context to tyre pressures
I have the active sport alloys on my car are they considered standard or loaded?
Or is loaded the type when your car is lowered?
I have got the 30 front and 32 rear on it at the moment, I thought rear needed 32 but I checked back with that site and it said 28.
What is the correct psi?
cataleptic_state
Punto Active Sport Mk2b 8V 3dr Manual 05
Formula1Reporter, Pricebargin.co.uk, CompareYourKnickers.co.uk, Horse-Master.co.uk,topendmotors.co.uk
catalepticstate is offline Reply With Quote Quote
Old 18-06-2009   #2
Geek of the Week
smokeyjoe03's Avatar
Trader Rating: 1
smokeyjoe03 has donated!
Aniki Pingpong Champion, Rat Zapper Champion, TIE Fighter Shooter Champion
Re: tyre pressures
I just always stuck 30 in all 4 and never had any issues, I had the same alloys as you, the active sport ones.
Rgards to loaded, it means when the car is laden (carrying loads of baggage) as obviously a heavier car would need higher pressure in the tyres.
That site is saying 30 in the front tyres and 28 in the back when the car is empty.
or 32 in all four tyres if you have a car full of stuff or four people in it.
The reason I put 30 in all of mine was because I had a sub in the boot and thought the rear tyres might benefit from some extra pressure.
smokeyjoe03 is offline Reply With Quote Quote
Old 18-06-2009   #3
Trader Rating: 6
Re: tyre pressures
Don't worry about it. 28-32 is fine.
Need alloy wheel spacers or bolts? PM me!
richie.guy is offline Reply With Quote Quote
Old 18-06-2009   #4
Geek of the Week
Trader Rating: 1
Re: tyre pressures
tbh I used to pump mine up at home with a compressor that had a needle so think and a guage so small you couldn't tell whether it was 28 or 32. So although I SAY it was 30 all round it probably was one or two PSI out tbf.
The local garage has a digital one but its a 50p coin operated on and I point blank refuse to pay 50p for fresh air
Old 18-06-2009   #5
Re: tyre pressures
Quote Originally Posted by richie.guy View Post
is that 28 front and 32 rear or around 28-32?
cataleptic_state
Old 18-06-2009   #6
Trader Rating: 6
Re: tyre pressures
Around.
Thread Tools
(T) Tyre pressures M1kbee Multipla 9 10-11-2009 12:01
(G) Tyre Pressures bitontheside Barchetta 1 28-11-2008 11:50
(G) Best tyre pressures? jongp Grande Punto 11 28-02-2008 15:19
(T) Tyre pressures. M@nticore Uno 0 08-07-2006 13:23
(T) Tyre Pressures no1sourlung Punto (Mk2/2b) 6 04-07-2004 19:16
