Hi Guys, i only read the last post after i had connected the battery this morning so i didnt leave it to idle for 5 mins etc but the warning light was still on anyway, i assume it should have gone out when i started it. Was thinking it may be the pre cat lambda as the garage said it may need one aswell as a new cat so i tried to check them doing the following.
With the engine idling i measured the voltage on the pre cat where i had a fixed 12v and the wire next to it was up and down, i then checked the post cat and that had the same 12v feed but the other wire was a steady 12 v instead of up and down, i assume this means they are working correctly, would i be right.
Regards
Jay
