| | Thread Tools | Search this Thread |
| | #1 |
Posts: 769 Thanks: 43 Trader Rating: 0 | gear cable im halfway through doing my clutch, but ive snapped one of my gear cables, its the one with the adjustable end, how much and where can i get one of these? also are the hard to do. i dont have a ramp im doing ll the work on the floor.
__________________ |
| | Quote
| | #2 |
Posts: 2,088 Thanks: 185 Trader Rating: 6 | Re: gear cable
__________________ Need alloy wheel spacers or bolts? PM me! |
| | Quote
| | #3 |
Posts: 769 Thanks: 43 Trader Rating: 0 | Re: gear cable
| | Quote
| | #4 | ||
Posts: 9 Thanks: 0 Trader Rating: 0 | Re: gear cable hi there they are only about 50 quid for a new one from fiat but it might not be broken the earlier cables had an insert pice that could be removed if it is this type u can pull back and twist the end of the cable where the spring is then locate the pice back in i have a set of cables i can put on ebay if u want for 30 posted for the both any way as for fitting its not that hard u need the car jacked up there is a white cover above the exhaust that u need to remove and the cables connect under there u need to remove the horse shoe clip and take the socket of the ball joint then it should be free to be pulled back through if u want any more advise or them cables putting on ebay then just pm me
| | Quote
| | #5 |
Posts: 2,088 Thanks: 185 Trader Rating: 6 | Re: gear cable Price wise they maybe cheaper for an 8v, the price I was given was for an HGT and it was a couple of years back. They come in one piece from the base of the gearstick to the top of the box.
| | Quote
| | simbasmum | Punto (Mk2/2b) | 11 | 22-03-2009 17:29 |
| | melkirn | Punto (Mk2/2b) | 1 | 30-10-2008 18:08 |
| | green_spock | Cinquecento / Seicento | 5 | 05-04-2008 12:25 |
| | jono_1uk | Punto (Mk2/2b) | 0 | 30-03-2008 13:41 |
| | pig | Multipla | 0 | 10-05-2007 15:24 |
