Technical Whats This Called?!? Part ID? Black box underbonnet
Hobbsy89
I'd appreciate any help with my MK1 (60s 1.2 8 valve), as im abit stumped! I have a few minor problems:
-rattling over rough ground on the front right (suspension?),
-whiny exhaust on start up,
-struggles to start 1 in every 50 times
But iv'e had a look under the bonnet, and theirs a box in the bottom/lower front left that has a Blue lead arching across the top of it. One end is connected to its hole, but the other isnt :S does anyone know what this box is, and what problems could this disconnection cause? could it be the culprit to any of my problems above? as shown in the pic the lead runs around to the back of the
to what i think is a spark plug and the altenator. Any help at all would be really apprecited! cheers guys.
that is the charcoal canister. part of the emissions control / vapor burn system.
it stores fuel vapour from the fuel tank and under the correct conditions it purges it into the inlet system.
where is it not connected?
Thanks Arc, I appreciate the Knowlege.
If you look on the first picture the blue lead, with the end closest to the camera. It should be sealed around the hole it hovers over, but it moves with the car. Any suggestions on what i should use to seal it??
And Karbineftw, please write your own thread or just copy and paste the picture.
Thanks Binki, Ive got half a scrapped punto on my drive i steal the part off. Whereabout does it disconnect? is it the black box with the two black cables that slides, or is it the rusty catch on the side?
