Thread Tools
Old 14-10-2004   #1
Broken fuel gauge???
Doh,
I have another irritating problem with my punto.
I've got an elx 1.2 V reg, its done 27000 miles and has a full service history. I've recently noticed that the fuel gauge has stopped working, its permanently stuck at halfway.
I done 90 miles and noticed no difference on needle, putting 10 of unleaded didn't make a diff.
Anyone else had this problem and how did they fix it. I've looked in my Haynes manual and all I can think of is replacing/cleaning the fuel pump and fuel gauge sender unit, but I'm not sure if that would do the trick. Any help much appreciated.
I'm no mechanic, but I've done a few bits on the car - would replacing the sender unit be something an amateur can do? Any idea how much a garage would charge to fix it?
thanks in advance
Dan
largeinnit is offline Reply With Quote Quote
Old 14-10-2004   #2
wolfracepunto has donated!
Re: Broken fuel gauge???
It will be the sender unit, its farely common on Puntos
Someone I know got charged about 150quid (iirc) for repair. Dont know about doing it yourself, the Haynes says nothing
BMW 123d M Sport Auto
'10 Focus ST-3 Gone
Hornet 600 K8 Sold
wolfracepunto is offline Reply With Quote Quote
Old 14-10-2004   #3
The sender units are quite expensive (150 seems about right I think) Fitting it is a doddle of a job although it can become more time consuming if you decide to light up a fag at the same time! On the Mk1 the unit is accessed through a panel under the rear seat.
FPS is offline Reply With Quote Quote
Old 15-10-2004   #4
Is the sender unit connected to both the gauge and to the little yellow low gas light? On my mk1 the gauge is always wrong but when the yellow thing flashes I have about 60-80KM more to go, so then its time to get more.
joel is offline Reply With Quote Quote
Thread Tools
(T) fuel problems, gauge and smell arc Cinquecento / Seicento 6 06-10-2006 22:04
(G) Optimax in a cinq Bushboy Cinquecento / Seicento 39 18-10-2004 20:37
(T) Fuel Gauge hell! leeapole Punto (Mk2/2b) 10 31-07-2004 03:15
(T) fuel gauge problem stringer97 Cinquecento / Seicento 1 20-02-2004 00:13
(G) Fuel Gauge pete1nlancs Panda (Classic) 2 19-01-2004 16:38
